The Saab Link Forums - View Single Post - Suspension Play Conundrum
Old 01-10-2017, 11:45 AM   #6
Trionic3000
Drew In Houston
It doesn't line up with all the syptoms exactly, but your firewall isnt cracked where the rack mounts is it? That would probably be more likely on the passenger side but.. Are the rod bolts that attach to the rack tight? Those are 3 and 9 o'clock problems though hmm
The good part about these setups being so crude is that there are only a few credible possibilities here I guess
Trionic3000 is offline   Reply With Quote
