The Saab Link Forums - View Single Post - Vacuum hose placement for 01 93 turbo
Old 01-10-2017, 08:37 AM   #2
g96nt
There's one in the engine bay. I forget if it's on the bottom of the hood, or the radiator support. It should be good-enough to get you going.
Realistically, There's only 2 vacuum lines. one for the Fuel pressure regulator, and one for the Bypass valve. you can cap the nipple on the throttle body-It's just a return for the bypass valve solenoid and skip the solenoid altogether.
Then, you just run the BPV and FPR right off the "tree" on the intake manifold.
Craig R.
2000 9-5
g96nt is offline   Reply With Quote
