The Saab Link Forums - View Single Post - 1992 9000
Thread: 1992 9000
Old 01-09-2017, 08:19 AM   #27
Daven
Daven's Avatar
Probably better to leave the 92's brake lines in place and fabricate an adapter to the newer non-TCS brake pump. On TCS 9000s, the pump has 4 outlets, because each brake is individually controlled from the pump. On non-TCS 9000s, the pump has only 3 outlets, because the rear brakes share a line from the pump and split somewhere further back.
I dont have any specs I'm afraid. Jordan Pagano at eEuro fabricated an adapter and the non-TCS brake system works flawlessly. Not sure what else will have to be swapped to make this work...might have to use a 1993 ABS ECU to be compatible with the rest of your 1992 engine management system...someone else should confirm this though. I mention this because, when installing a TCS defeat switch on a 1992 9000 you need an ABS ecu from either a 1993 9000 CSE Turbo or a 1993 9000 Aero.
Of course if you're performing a T5 swap/TCS delete at the same time, you probably wont have to worry about compatibility. Again, there are far more knowledgeable people on this subject; maybe they will chime in here.
1995 9000 Aero - Jordan Pagano tuned 390hp
2002 9-3 Viggen vert - Jordan Pagano tuned 300hp
2004 9-5 Aero Wagon
Daven is offline   Reply With Quote
