The Saab Link Forums - View Single Post - 1992 9000
Thread: 1992 9000
Old 07-01-2016, 02:30 PM   #15
Troup
Troup's Avatar
Send a message via AIM to Troup
Originally Posted by Daven View Post
With a complete 1994 Aero as a donor car this should be tedious but hopefully fairly straightforward. When removing brake lines and brake pump/booster elements, take your time. Use lots of PB Blaster, tapping, PB, tapping, PB to loosen the connections...I BROKE 2 OF MINE like a ham-fisted moron.
One thing you might find is that your 1992 TCS pump has 4 brake line outlets (2 front, 2 rear) wheres non-TCS 94 pump has only 3 (2 front, 1 rear). In which case, you'd need to couple the rear brake lines into 1 and connect. This may not be the case for you, but it was for me with my 1995.
Killer combo; the best of both 9000's. Good luck!
Thanks for the advice, I definitely will do that. Good to know that the pumps are a little bit different. I haven't been able to find much info on them. I would never attempt this if I didn't have a fully functional donor car.
-1992 9000
-1994 9000 Aero
-2002 9-5 Linear
-2006 Explorer Eddie Bauer
Troup is offline   Reply With Quote
